Exponantial contraction in fluid systems
tifoso
Materials
Jul 6, 2010
4
I am trying to find a exponantial variation in the pipe crosssection. Crosssection area must be decereased in an exponantial behaviour. Is there a formula for that. If there is how can I find it.
No, I looking a formula that describes the shape of the pipe. Pipe crossection decreases or contracts in an exponential behaviour. Or transition between large pipe and small pipe must be governed by an exponential formula. How ca I find that.
Stop looking for that and start looking for a mistake in the specification. Sounds like some computer program did the translation.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
"Being GREEN isn't easy." Kermit[frog]
biginch if you wont answer properly dont write anything. no one has to read your smartass answers and very good english language level...
Ooh er Titsoso .... dummy and toys flying out of the pram there !
Pipe diameter transitions may be conical or belled/concavo-convex, but their exact shape is governed by forming limitations, not by equations.
I.e., your question, viewed from our end of the Translation Tunnel, seemed a little bit silly.
Therefore Big's response was entirely appropriate, and constructive.
Mike Halloran
Pembroke Pines, FL, USA
Crane's Technical Paper 410 "Flow of Fluids" might be of help if you're wanting formulas to size piping (though I'm not exactly sure what is meant by "Cross-section area must be decereased in an exponantial behaviour." Why MUST it be decreased exponentially?)
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
