JAYDEE66
Aerospace
- Jan 6, 2020
- 13
I have Found a great journal online that creates a PDF of all the drawing sheets in the current part file. What I would like to have is a journal that will pause and let me select which sheets I want in the PDF file. example. If there are 8 sheets and I only want sheet 2 and 4 to be in the PDF file I would like to be able to select only sheets 2 and 4. I have limited journal experience and could use the help. if anyone knows where there might be a journal like this online I would appreciate it if you could share it.
thank you
thank you
