Export DRG file to PDF file in local drive from Teamcenter without opening a drawing file CGM in NX
Eng_Lax
1
Greetings,
From teamcenter (not from UG / NX) without opening a drawing file / CGM can we export part drawing as pdf file in local drive.
We need to share these drgs in PDF format to supplier / Manufacturing.
If we could get drgs files as PDF it will be beneficial in terms of times savings and efforts reduction.
Most of the times more than 1 drg sheets per drg are there, also we need to export for multiple parts too..
So if we could able to export PDF's from directly teamcenter by only selecting multiple drg files will be beneficial.
