export features to new part
clamschlauder
18
Hello all, I am a SW guy trying to adapt over.
I have a situation where I need a plate to follow a somewhat complex shape. The plate needs to follow the pattern as it will be welded into place on my main part. I would like to create that feature in my main model and then export it out as a new file. I tried to search for this problem but couldn't find exactly what I needed.
So what you wan to do is create the part in the assembly, then export to be its own part . . . correct?
When you are done modeling it in the assembly just go to:
Assemblies (pull-down) -> component -> create new component
Let us know if you have questions from there
Jerry, seems to work fine only that when it creates the new part it also keeps my main part too. I will try to explain better. I have an engine block and I am making water jacket plates. I do what you say and create new component and label it "water jacket". It comes up in the assembly navigator as model1. When I suppress the main engine block model 1 is a model of the block and the plate. When I hang the cursor over the plate it shows the label of that part as water jacket. Under the sub part model1.
Check out the options in the 'Settings' section of the 'Create New Component' dialog.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
yes, there is a "delete original" setting that should be toggled "on"
I think I have tried most of the setting combinations and still the same thing. Would it matter if this part has an extrusion defined by a surface of the original part? I am not sure what else it could be
So on another part I made another water plate that was only defined by a sketch and extruded. It was created with no problems. So that brings me back to the problem with this certain instance. I have created a tube with start and end defined by extended surfaces. I created a sketch to subtract about half of the tube going down the length so it looks like a half pipe. I believe that feature is giving me the issue.
