cubalibre000
- Jan 27, 2006
- 1,070
it's possible to set a default path in the export to PDF mask ?
If I browse in a folder I need to set the file name also and this file it used for every next PDF file.
For example if I browse in C:\Documents and Settings\Rossi\Desktop\Pippo.pdf
and after I export 'Pluto' to PDF, NX produce again Pippo.pdf
I would like only set a default path and the PDF name is taken by the specification name.
Thank you...
Using NX7.0 and TC8.1
Thank you...
