Export pro-e drawing to autocad layers
parbs
1
Greetings, we produce product drawings in pro-e and export them to autocad for my manufacturing plants. At my plant, they use a standard layering scheme with specific naming conventions. Is it possible to configure pro-e to export layers to a different format that does not include standard pro-e names. ex. dxf_axis ..... etc
Yes,
In config.pro, use your naming convention, See the example below:
def_layer layer_datum PLANES
def_layer layer_csys CSYS
def_layer layer_axis AXES
def_layer layer_point POINTS
def_layer layer_curve CURVES
def_layer layer_surface SURFACES
def_layer layer_note NOTES
def_layer layer_dwg_table TABLES
def_layer layer_gtol GTOLS
and so on.
-Hora
Also check this thread554-13324 and read Ohio's post.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
