  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
export stress data of selected nodes, write macro
veitweight
Materials
May 7, 2015
1
hi,
im very new to ansys apdl. i want to export the forces and x-location of my previously selected nodes.
im very new to apdl-coding and therefore have no idea how to export it into a pdf via macro. i would even like it way more to directly write it into a .xml for excel.
i want to get the x-location and stresses Sxx, Szz, Sxy, Sxz. actually i need a path with the x-value starting from the first node but i think i can change the x-location data in excel to get that easily.
this is what i found so far:
FLST,5,3,4,ORDE,3
FITEM,5,29
FITEM,5,41
FITEM,5,-42
LSEL,S, , ,P51X
nsll,s,1
! selects my nodes on selected lines
*get,NCOUNT,node,,count
*dim,NARRAY,array,NCOUNT,5
/post1
set,last
*cfopen,temp,txt
*vwrite
('x-loc',8x,'Sxx',10x,'Szz',10x,'Sxz',10x,'Sxy')
*vget,NARRAY(1,1),node,1,loc,x
*vget,NARRAY(1,2),node,1,s,x
*vget,NARRAY(1,3),node,1,s,z
*vget,NARRAY(1,4),node,1,s,xz
*vget,NARRAY(1,5),node,1,s,xy
*vwrite,NARRAY(1,1),NARRAY(1,2),NARRAY(1,3),NARRAY(1,4),NARRAY(1,5)
finish
it doesnt work yet. i think i need *do and *endo commands but i have no idea how to implement them.
in another thread of this forum someone exported it directly into excel format:
*CFOPEN,C:\Temp\RESULTS_Face,xls,,
*VWRITE,
('X Y Z UX UY UZ USUM ROTX ROTY ROTZ ROTSUM')
*VWRITE,RESULTS_Face(1,1), RESULTS_Face(1,2), RESULTS_Face(1,3), RESULTS_Face(1,4), RESULTS_Face(1,5), RESULTS_Face(1,6), RESULTS_Face(1,7), RESULTS_Face(1,8), RESULTS_Face(1,9), RESULTS_Face(1,10), RESULTS_Face(1,11)
(F17.9,' ',F17.9,' ',F17.9,' ',F17.9,' ',F17.9,' ',F17.9,' ',F17.9,' ',F17.9,' ',F17.9,' ',F17.9,' ',F17.9)
*CFCLOS
can anyone help me with this? i need to do this for my master thesis and i have no clue about apdl coding :(
I'm with the same problem, and I am astonished I cound't find answer on the internet yet.
Did you solve? Could you share the code?
Actually, I would like to export the coordinates and displacements of each node in order to make same analysis using Matlab
I started with the code below, but there're some mistakes
/OUTPUT MyOutput, txt
*GET, NoNodes, NODE, 0, COUNT !Get number of nodes
*DIM, MyTable, TABLE, NoNodes, 6, 1,,,,0 !Declare matrix to get coordinates and displacements
*DO, i, 1, NoNodes, 1
*vget,MyTable(i,1,1), NODE, i, LOC, X !Save Coord. X of node number i
*vget,MyTable(i,2,1), NODE, i, LOC, Y
*vget,MyTable(i,3,1), NODE, i, LOC, Z
*vget,MyTable(i,4,1), NODE, i, U, X !Save displacement X of node number i
*vget,MyTable(i,5,1), NODE, i, U, Y
*vget,MyTable(i,6,1), NODE, i, U, Z
*ENDDO
/OUTPUT​
I also tried another code, this seems to be more simpple, but didn't work either.
*DO, I, 1, NoNodes,1
Set, I
*CFOPEN, OutputFile,txt
*VWRITE, NX(I), NY(I), NZ(I) !Save in a file
(G30.15, ' ',G30.15, ' ',G30.15, ' ',G30.15)
*VWRITE, UX(I), UY(I), UZ(I) !Save in a file
*CFCLOS
*ENDDO​
And, finally, this one solved the problem:
*DIM, ANODES, TABLE, NoNodes, 6 !Declare table to save coordinates and displacements
*VGET, NODELIST, NODE, ALL, NLIST
*DO, J, 1, NoNodes,1
*GET, ANODES(J,1), NODE, NODELIST(J), LOC, X
*GET, ANODES(J,2), NODE, NODELIST(J), LOC, Y
*GET, ANODES(J,3), NODE, NODELIST(J), LOC, Z
*GET, ANODES(J,4), NODE, NODELIST(J), U, X
*GET, ANODES(J,5), NODE, NODELIST(J), U, Y
*GET, ANODES(J,6), NODE, NODELIST(J), U, Z
*ENDDO
/OUTPUT, OutputFile,TXT,,APPEND
*VWRITE, ANODES(1,1),ANODES(1,2),ANODES(1,3),ANODES(1,4),ANODES(1,5),ANODES(1,6)
(G30.15, ' ',G30.15, ' ',G30.15, ' ',G30.15, ' ',G30.15, ' ',G30.15)
/OUTPUT
But, pay attention to the following comment: this code works because I'm using APDL inside Workbench. When using just APDL, the seccond part (the VWRITE format) may not run, than, it can be necessary write this part inside another file and then import:
*ENDDO
/INPUT, OtherCode, txt
/OUTPUT
