Exporting multiple bodies to a single STL file
pittbuck
Computer
Hey NX Fam!
I am trying to utilize this journal to grab all bodies that are on Layer 36 as a single STL file. The number of bodies will typically range from 2-8. When I run the journal below, it only grabs one of these bodies and it isn't totally consistent which one it is. Please send help!
Thanks in advance!!
Code:
' NX 8.0.0.25
' Journal created by zbuckler on Thu Aug 24 09:04:00 2017 Central Daylight Time
Option Strict Off
Imports System
Imports System.IO
Imports System.Collections.Generic
Imports Microsoft.VisualBasic
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Dim theSession As Session = Session.GetSession()
	Dim displayPart As Part = theSession.Parts.Display
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        lw.Open()
		Const undoMarkName As String = "export solids to STL"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, undoMarkName)
        Dim theSolids As New List(Of Body)
		Dim currentFile as string
		currentFile = GetFileName()
		Dim currentPath2 as string = "\\Cagenixserver\Cagenix Data\Production" & "\" & currentFile & "\" & currentFile  & " APPROVAL"
	msgbox (currentFile)
		Try
			'Try to create the directory
			Dim di As DirectoryInfo = Directory.CreateDirectory(currentPath2)
			Console.WriteLine("The directory was created successfully at {0}.", Directory.GetCreationTime(currentPath2))
		Catch e As Exception
			Console.WriteLine("The process failed: {0}.", e.ToString())
		End Try
        'collect the solid bodies in the work part
        For Each temp As Body In workPart.Bodies
            If temp.IsSolidBody andAlso temp.Layer = 36 Then
                theSolids.Add(temp)
            End If
        Next
		Try
            ExportSTLFiles(currentPath2 & "\" & currentFile, theSolids, 0.01, 0.01)
        Catch ex As NXException
           lw.WriteLine("NX Error: " & ex.Message)
        Catch ex As Exception
           lw.WriteLine("Error: " & ex.Message)
        End Try
        lw.Close()
	'   Menu: File->Save
	Dim partSaveStatus5 As PartSaveStatus
	partSaveStatus5 = workPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
	partSaveStatus5.Dispose()
    End Sub
    Sub ExportSTLFiles(ByVal FileName As String, ByVal theObjects As List(Of Body), ByVal triangleTolerance As Double, ByVal adjacencyTolerance As Double)
        Dim NumErrors As Integer
        Dim InfoError() As UFStd.StlError
        Dim Header, FileBaseName As String
        Dim numNegated As Integer
        Dim Negated() As Tag
        Negated = Nothing
        InfoError = Nothing
		Dim parentFolder As String = IO.Path.GetDirectoryName(FileName)
		Dim fileNameNoExt As String = IO.Path.GetFileNameWithoutExtension(FileName)
        FileName = IO.Path.ChangeExtension(GetFileName & " MINIMUM COPING SUBTRACTIONS", ".stl")
        For Each temp As Body In theObjects
           Dim FileHandle As IntPtr
           FileBaseName = IO.Path.GetFileName(FileName)
           Header = "Header: " & FileBaseName
           theUfSession.Std.OpenBinaryStlFile(IO.Path.Combine(parentFolder, FileName), False, Header, FileHandle)
            theUfSession.Ui.SetPrompt("Creating file ... " & FileBaseName & " ...")
            theUfSession.Std.PutSolidInStlFile(FileHandle, Tag.Null, temp.Tag, 0.0, 0.0, triangleTolerance, NumErrors, InfoError)
            theUfSession.Std.CloseStlFile(FileHandle)
            theUfSession.Ui.SetStatus("File ... " & FileBaseName & " generated ...")
       Next
    End Sub
	Function GetFileName()
		Dim strPath as String
		Dim strPart as String
		Dim pos as Integer
		'get the full file path
		strPath = displayPart.fullpath
		'get the part file name
		pos = InStrRev(strPath, "\")
		strPart = Mid(strPath, pos + 1)
		strPath = Left(strPath, pos)
		'strip off the ".prt" extension
		strPart = Left(strPart, Len(strPart) - 13)
		GetFileName = strPart
	End Function
	Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
       GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
If I recall correctly, at least in terms of what is exported from NX, an STL file can only include a single body. If you're attempting to stage multiple bodies so as to maximize the utilization of the build space of the 3D Printer, I thought that that sort of thing was done using the staging software provided by the 3D Printer vendor.
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
UG/NX Museum:
This code might help you. It will put all the solid bodies from the part into a single STL file. However, when you import the file, all the bodies will be treated as one. If you round-trip the file back to NX, the 'convergent' body option will only import a single body. The other options (NX or JT) will import all the bodies, but they will collectively be considered a single object.
www.nxjournaling.com
cowski,
Once again, you have directed me to the right code. I had some things "out of order" in my initial code, which is why only one body was being exported instead of all bodies. This helped a lot! Thank you!!!
