Expresiones_that_a_value_returns_three
manu1973
Aerospace
ES
Hello
I would like to know if the following can be done:
I want a numeric value to modify 3 values (3 dimensions)
example:
I call my part washer DIN-125 M_4
Well, that last number "4", I want it to return 3 values
value h = 0.8
value d1 = 4.3
value d2 = 9
I pass you sample pdf
Thank you so much for everything
 https://files.engineering.com/getfile.aspx?folder=eaf5defb-65f5-4990-9894-af21e4970b0c&file=Expresiones_that_a_value_returns_three.pdf
What you need to do is build a re-use lib for your washers to cover the range
_3
_4
_5
_6
and so on
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
Yes, I know that it can be done as you say, with the reuse library, but I have a problem, with the license I have, I can't use the reuse library, so I have to try to do it in another way, I had thought do it with expressions.
I understand that it can be done, because with programming, everything can be done.
Thank you very much for answering
You will need some expressions:
A handle exp Ex.: x = 4
A table with all data
ex. Table={{4,0.8,4.3,9},{...}}
In each expression you look in the table you will need a loop formula
Ex. H =
loop {
for $set in Table;
if ((x = nth(1,$set))) Return nth(2,$set);
Return is 0;
Gelson Z. Nicoletto
V.18-NX1980
