haynewp
- Dec 13, 2000
- 2,327
For those of you that provide supports for large exterior ducts on industrial type buildings, does the mechanical engineer provide you with the required duct support spacing or do you determine the spacing and design the duct wall thickness for a given diameter? I’ve never designed a duct before and am having trouble getting someone to provide me with the support spacing they need on a project. These ducts are over 20 ft in the air and are bending under wind and snow loads and need steel supports cantilevered from the ground.
