Exterior elevator shaft addition to an existing building with cmu walls. Dimension are 20'x22'x28' tall.
The question is, would it be incorrect to design the cmu spanning vertically? Are the walls supposed to be designed to span horizontally in the shorter direction?
Obviously the shorter direction would likely cost effective but ignoring the numbers, my question is more about the design approach.
