Nereth1
- Feb 2, 2014
- 136
Hi all,
I have found nominal external circlip groove dimensions at various sites, such as this one: , which I assume are valid and come from DIN 471 (which I don't have).
I typically use the above dimensions in machinery designs without issue, but our main product line deviates (or we want to deviate it) significantly from the nominals - and I can't form a good argument either way. There are two scenarios:
1) Circlip depth
Our circlip depths are typically much deeper than the standard. The person who set it said that he did so by experimentally deepening the grove until the gap in the split was back to its pre-stressed size - i.e. there would be very little deformation in the circlip. The best reason I have to not do that, is that the circlip should not have radial clearance for fear of spinning around the shaft and wearing, or going skew from the shaft axis. Neither of these feel like strong arguments. By contrast one could argue that the shallower grooves in the standard are more prone to the circlip being forced out of the groove. What is the established knowledge here? What happens if the groove is too deep or does it not matter?
2) Circlip groove width
Currently we have an opportunity to enhance manufacturability by increasing circlip width, but again the question is what are the detrimental effects. I have noticed that where groove dimensions are listed, typically width is listed as a minimum with no maximum. Intuitively, while under load, the position of the non-load-bearing side of the circlip groove doesn't matter as it is not touching anything. However circlips are not always under load - some searching found stories of Honda NSX transmission failures due to circlips going sideways in an excessively wide groove. I can't quite understand that failure mode though so I am hesitant to assume it applies to us. Again, what happens if the groove is too wide, in an application where it is not always loaded, and in fact the item it is retaining can happily retract a few mm from the circlip groove (thus allowing the circlip to shift)?
I wander if the two items are related - the circlip cannot go skew on the shaft unless both the depth and width are too high?
Thank you in advance for your responses and expertise.
1) Circlip depth
