a1987
- Oct 5, 2012
- 27
Dear Sirs
for several gear pumps, on process data sheet is present the indication of an external downstream pressure switch...and for those pumps is not present the indication for internal relief set..
i think internal relief valve should be provided and its set pressure too, regardless external downstream pressure switch..
what do you think about?
