Extracting stress in intersecting points of bodies 1
BTHS
8
Hi
I've setup this model in Ansys workbench. It's a 2D model, and it has been sliced and combined in Designmodeler to make the mesh comply to the specified lines. I would like to extract the stress in this intersection (Marked by the two green dots), but i'm getting an error: "You have a result that is attached to an entity shared by more than one body. The solution cannot proceed until this is fixed.". I could choose to select the nodes and that works, but as this is a parametric model where the geometry changes this method breaks down. See photo below:
Best Regards
Hi BTHS,
Would this work for you?...
Step1: Create name selection 'line1' and 'line2' in DesignModeler/SpaceClaim. These lines share that one node of interest.
Step2: Add Post Command Snippet below:
Code:
! Find node of interest
cmsel, s, line1
cmsel, r, line2
*get, nodenum, node, 0, num, min
! Use your *get function. An example below.
/post1
set, last
*get, my_sout, node, nodenum, s, eqv
Step3: Create parametric results argument in "Details of Command Snippet": my_sout
Best regards,
Jason
Hi Jason
Thank you for a fast and accurate response.
I modded the code to exactly fit my purpose:
Code:
! Find first node of interest 0.4*t from the weld
cmsel, s, line1
cmsel, r, line2
*get, nodenum1, node, 0, num, min
! Find second node of interest 1*t from the weld
cmsel, s, line2
cmsel, r, line3
*get, nodenum2, node, 0, num, min
! Use *get function to acquire 1st principal stress in selected nodes
/post1
set, last
*get, HS_04, node, nodenum1, s, 1
*get, HS_10, node, nodenum2, s, 1
It is working very well. One thing i noticed was when i wanted to edit the "Par" name in "*get, HS_10, node, nodenum2, s, 1" i had to also change the output search prefix to HS_ .
One problem i have is if i have to change the code and rerun the analysis i get this error:
"The solution was executed using only post commands information. Check the Post Output on the Solution Information object for more details"
My it can be fixed by clearing all result data and rerun analysis, but the method seems a little rough. Is there a more smooth solution to this?
Best,
BTHS
BTHS,
The problem could be due to the DB file not automatically saved so it's complaining no named selection exist.
Try the following:
Step1: Set "Analysis Settings>Analysis Data Management>Save MAPDL db" as "Yes".
Step2: Modify your Post Command Snippet:
Code:
finish
resume,file,db
/post1
set,last
cmsel, s, line1
cmsel, r, line2
cmsel, s, line2
cmsel, r, line3
set, last
Step3: Clear Generated Data for your Solution and solve again.
After the above steps, the Post commands should run with any new snippet changes.
Best regards,
Jason
Hi Jason
That worked. Thank you so much for your help!
Best,
BTHS
