JoachimAlly
Bioengineer
- Nov 12, 2014
- 16
Hi fellow engineers,
I have a quite simple question, but I don't know if it is possible in Siemens NX. I searched in the Help and on the net but didn't found a solution yet.
Is it possible to draw a line or curve and then extrude it to a cilinder just by specifying diameter of radius? The line or curve is than the curve passing trough the middle of the cilinder.
I want to share the background information: I am designing a cap for positioning on a rodents head to measure EEG. It has 30 holes in the cap where I want to install electrodes afterwards. Due to the fact that the rodent will be in the same time in a MRI-scanner I can only let the wires come out at the back of the cap, so I have to design tunnels in the cap for the wires. The attachment explains the same in pictures.
An additional question I have: can the routing electrical mode be of some use in my case?
Kind regards,
Joachmi
Kind regards,
Joachmi
