Hi All,
This is my first post so sorry if I have made any mistakes. I am facing issues during case carburizing of universal joint crosses of 20MnCr5 raw material. I am observing black spots in the core microstructure after carburizing. These spots are visible are etching and polishing and also visible under a microscope. Photographs are attached ( These spots go away if I re-quench and temper the part. Photographs of the re-quenched and tempered parts are attached ( I have taken trials with different lots from the steel mill and the results are the same. I have also tried to measure the hardness (with micro-Vickers tester) at that particular location and there is no change from the surrounding areas. I have also taken special care while preparing the cut sample to see that the spots are not a result of sample preparation. Also since these are not observed after re-quench and temper, I do not think it is due to improper sample preparation. The furnace and quench oil are the same for the case carburizing operation and the re-quenching operation. All other aspects of the micro-structure, the surface and core hardness, and the case depth are found to be OK (within spec). I am not finding these issues in other components we do on the same furnace. Please help me figure out what these black spots are? and why are they occurring. Details of the process are below:
Case carburizing process:
Furnace: Seal Quench Furnace of 600 kg capacity
Quench Oil: Hi-quench MF (Hardcastle)
Boost cycle: Time=4.5 hrs, CP=1.15%, Methanol: 2L, Temperature: 940 C
Diffuse cycle: Time= 2.5 hrs, CP=0.75%, Temperature: 940 C
Hardening cycle: Time=1.5 hrs, CP=0.75%, Temperature: 860 C
Case depth: 1.2 to 1.5 mm, Surface hardness: above 63 HRC (as quenched), Core hardness: 320-330 HV
Re-quenching cycle:
Furnace: Seal Quench Furnace of 600 kg capacity -same furnace
Quench Oil: Hi-quench MF (Hardcastle) - same oil
Hardening cycle: Temperature: 870 C, Time= 2.5 hrs soaking (after attaining the temperature)
Thanks,
Re-quenching cycle:
Thanks,
