Factor of safety for composite pressure vessel
boeri
Aerospace
Mar 12, 2004
13
I am designing a subsea composite pressure vessel (mainly loaded under external pressure). Can somebody provide me information about the factors of safety that need to be applied. I suppose it most be more than 1.5, due to the underwater environment and the unknown influences it can encounter. The purpose of the vessel is to deliver buoyancy in a range between 500 m and 3000 m below sea level.
Thank you in advance, it would be of great help.
Boeri
A composite shell requires careful design: particularly under external pressure. Shell length betwwen stiffeners is governing factor for resisting pressure - sort of holds the section circular.
In the Uk we use BS4994:87 and the MINIMUM K factor is 8 and frequently in the range 8-14.
Trust this is of help.
Ed
Ed Clymer
Resinfab & Associates
England
boeri, You may want to check the ASME Code for RP stamped vessels, Fiber Reinforced Plastic Pressure Vessels, Sec. X.
Hope this helps.
saxon
Thank you for the indication!
Wow, 8-14 seems a lot!!!!
I will surely check out the Codes...
Boeri
