Hi Everyone,
I am trying to validate the design by verifying that the design will withstand the applied load. Just want to know what will be right to use interms of figuring out failure load.
Yield stress or tensile stress? The ultimate yield only gives you the Force where it starts to deform but ultimate tensile will give me the force at which it shall fail. I have got both yield and tensile of all the materials except for the screws (which is most likely to fail before others - hoping to get it from the supplier today) and I am approximately through some tests figuring out the Force applied area (its not easy! especially with screws).
My question is in product design environment what stress do you use to work out failure? I will have some safety factors on the loads later.
V
V
