structuresguy
We are looking at some windows in an existing building which have been questioned as to adequate connection of the window frame to the structure. The frame is extruded aluminum, with a 1x wood board around the aluminum. The frame is screwed into light gage metal studs. The screws pass thru the aluminum frame, thru the wood 1x, and into the metal studs.
It seems to us that this puts a large eccentricity on the screws, approximately 2+". Basically we feel the wood does nothing but act as a spacer. However, it may keep the screws from bending due to the confining effect of teh wood.
Anyone have any insight into the failure mode of this condition. We can look at the shear capacity of the screws to determine if the windows have enough fasteners for the wind loads. However, with this eccentricity, some reduction of capacity must occur.
Thanks.
Thanks.
