leont
- Sep 5, 2007
- 39
THE POINT TO DISCUSS IS, FAILURE OF THE BELLOWS ON SAFETY RELIEVE VALVES
I have not a huge experience with this kind of failures on safety valves.
This has been a recurrent issue and never a failure analysis has been completed. In the past the fuequency of failure was between 4 and 6 months. Original investigation showed stress corrosion cracking initiated from the outside of the bellows. The bellows were upgraded to Inconel 625 however the failure shows up over and over. Last failure happend two days after new PSV installation.
How big could be the back pressure on the bellows to cause the collapse of the bellows?
Do we really need a big back pressure or just small one will be enough for a big damage?
I will be talking to vendor shortly. However, how can I calculate what this back pressure value is?
Thank you in advance for your support
leont
leont
