Hannes
- Jun 17, 2003
- 2
I have been looking at condensate pan design in fan coil units (FCU). How prevalent is the practice of using only a minimal sized condensate pan on coils installed on an angle?
I have worked with only a small sampling of FCU's for residential condo's and they seem to have the condensate pan only at the coil's lower corner, apparently feeling that the surface tension of the water will stop drips (doesn't work well if the coils have excessive dust, debris or if something goes wrong).
Is the use of minimal sized condensate pans normal?
What companies design the FCU's with a full pan?
Thanks.
Thanks.
