imagineersinc
Industrial
- Feb 5, 2025
- 2
I am looking for some good videos online regarding simulation analysis of a fan. A bit about the fan DC Fan Ball Bearing 220MM 48V 103W 6500RPM (PABST 2218F/2TDH) . There would be 10 mounted to a fan panel. Each fan itself would be mounted to its own smaller square plate using 4 x M4 nylock nuts and bolts. The smaller square plate would then be mounted using thumbscrews to a larger panel. My question or concern it that if these fans are running 24-7 for say 5 years on this setup that the thumb screws may eventually start to vibrate and back out. Maybe its an invalid concern but would like to try and simulate this if not figure it out even by hand using solidworks. Suggestions? Comments?
