SilverRule
Chemical
Hi guys,
I just don't seem to get this topic fundamentally and also how to actually apply it. Just focusing on compressible flow by the way.
Wikipedia starts by saying "Fanno flow is the adiabatic flow through a constant area duct where the effect of friction is considered."
Basically, I don't see what makes this a unique and separate category. It doesn't sound special at all. Constant area is the simplest assumption and is the default case while analyzing any typical generic pipe flow. As for friction, where is friction NOT considered? Friction is like the base default phenomenon that is fundamental in all flows. Pretty much all real life pipe flow calculations consider the effect of friction by default. Why does this have to be mentioned specifically? If you DON'T consider friction, that's when you would highlight that because that wouldn't be normal. So do they mean something different by it?
The fact that it's adiabatic is the only thing special about it.
The other part that is completely unintuitive about it is this concept of frictional choking (as opposed to sonic choking) that comes up in relation to this topic. Like this statement: "for a flow with an upstream Mach number less than 1.0, acceleration occurs and the flow can become choked in a sufficiently long duct".
From all of my experience messing with fluid flow software and understanding of theory, it should be the opposite. Meaning...for a given pressure differential, the shorter the pipe the more likely it is that there will be choking at the endpoint. If you have a longer pipe, the fluid can move at a lower velocity lowering the chance that it will reach Mach = 1.
What am I not understanding?
