I will try to explain my problem as clearly as possible.
Until recently our LVD Orion 3015 Laser has been great. It is equipped with a Fanuc 2.5KW Resonator.
Now, when running a program at some point the beam will stop. The axis will continue to move and the program will continue to run but the beam will disable. (I cannot enable the beam again unless I shut down, then re-start the resonator.)
I have been on the phone with LVD but they say they are not sure what may cause this to occur.
I am really hoping that someone out there can possibly point me in the right direction.
If you need anything clarified feel free to ask.
Thank you kindly.
Thank you kindly.
