Fast Catia Save file..... 4
CAD2015
Computer
Jan 21, 2006
2,026
I need to create a new CATPart(shield), required in a big assembly (engine).
What is the fastest way to get a copy of this assembly? Stp file takes a lot of time.........
CAD 2015
save assembly as CGR or HSF?
Eric N.
1. Tools > Generate CATPart from Product
2. You might look into exporting the entire big assembly as an stl or iges file just to get a small, manageable file in order to create the surrounding shield.
3. Uncheck "Load referenced documents" in Tools > Options > General tab and then only selectively load the engine components you will need for the shield.
4. Work with the cache system to make life easier on your machine when working with big assemblies.
Drew Mumaw
Bitcoin: 1979xGTQt7VMMGsr23hpkrnAWR1jCf7dZx
drewmumaw,
What have you meant by "Working with the cache system to make life easier on your machine when working with big assemblies" ?
How to get that?
CAD 2015
Eric N.
Thanks a lot, Itsmyjob!
[2thumbsup]
CAD 2015
It looks like the "Options" on my Catia is system administrator locked, right?
CAD 2015
Yes. Yours are locked by your Administrator - you'll have to talk with whoever controls your CATSettings.
Working with the cache system allows you to load cgr representations of the 3D instead of the raw CATIA design data. It can help when working with large assemblies where you need to see a representation of the surrounding 3D, but only need to make changes to one part by putting it in design mode.
Drew Mumaw
That's why is good to work with Enovia VPM or another solution like that...it will allow you to create a volume filter around your CATPart (environment) and make your life easier...in VPM you have also a light viewer and do even an easier load in CATIA...you can create also a volume around a whole bundle...
VPM is just one example...there are also some other solutions, some companies developed customized solutions just to load faster a huge environment... I've done something similar for my company just to load over 15000 part instances in few minutes (not so many [bigsmile] ), but for sure there are more professional solutions out there (like dVISE, TREND...).
Fernando
- Romania
- EU
