Fast switching SSR SPDT (Solid state Single-Pole-Double Throw) Relay
Ethnan
53
Good day Noble Minds,
I need a fast switching SPDT relay(not less than 1Khz) to implement the circuit below.
Both S1 switches will close to terminal 1, when both S2 switches close to terminal 2 and vice versa.
Your recommendation of any available module in the market will be highly appreciated. All the modules I have seen so far have switching speed of about 10ms (100Hz) .
With a 40 Hz signal, switching faster than 40 Hz or possibly 80 Hz seems needless.
I suspect that the solid state relays will depend on zero crossing switching.
I want to get each cycle waveform chopped like 25 times. Yes, need zero-crossing, but not an issue, I have taken care of that.
