MOSFET or similar devices that hold their state when unpowered.
jrodh
I am trying to identify a solid state device that will retain it's state when not powered. For example, I know that flash memory stores it's state by means of a floating gate that is capacitively charged and isolated from the drain/source. Unfortunately, I need a single discrete solid state device that will do this while passing a fair amount of current (>1 amp). I have considered a solid state relay, but I can not find a design that can retain it's state like a mechanical latching relay when it looses power.
Does anyone possibly know of a single discrete device that has such a capability, or a small circuit that could somehow manage to do this? I simply cannot find a solution using solid state devices.
EEPLD is still a currently used term/abreviation.
The original request is ambiguous. Latching relays retain their state even if the remainder of the control system is disabled/unpowered. An (E)EPLD won't drive a mosfet gate if the (E)EPLD is not powered. Not sure how long the static charge will remain on a mosfet to push it to saturation though I recall that allowing them to float is just good fun (not).
Without a useful understanding of the final application, we're shooting spitballs at the wall. We need more info...
Dan - Owner
These are all awesome responses!! I had no idea I would get so many in so few days! Thank you.
I will investigate EPLD, reed switches, and SCR solutions. Core memory (while interesting) will not work.
Thanks!
Sorry i dont think theres anything out there.....is it for an array of cells?
I already looked deep into this, theres nothing that will stay on when not powered.
Maybe enhancement mode mosfets though....sorry, i mean the very opposite of that...the fet that needs an active signal to turn it off...i forget the name
For how long does the state need to be retained? I'd guess a simple CMOS flipflop driving a non-protected gate MOSFET powered by a lithium coin cell could maintain its state for years.
