Qluq
Marine/Ocean
- Jan 22, 2014
- 32
Hi everyone,
on our carbon spar with aluminium brackets attached, we tried to prevent galvanic corrosion by applying glass separation plies between the aluminium and carbon parts. Where glue is not sufficient, the brackets are connected to the spar by titanium bolts with titanium or stainless steel washers and stainless steel nuts, some of which are silver plated. The bolt shanks contact the carbon in the spar hole, and contact the aluminium in the bracket hole, we did not put any isolation between the holes and bolt shanks.
We put a test section of spar with a titanium bolt, stainless washer and stainless nut in a thin layer of salty water and are seeing corrosion on the washer and nut. The test is too simple to draw any conclusions, but it does make us wonder...
Is this in your opinion a sound enough way of preventing galvanic corrosion, or would you recommend different material combinations, additional isolation (eg between shank and hole, how would that be done?), or some solution we have overlooked altogether? We will be flying under an experimental certification, we expect to not have a lifespan of ages, about 2 to 3 years. However, we will be flying near the sea, so salty water around plenty.
Also, what literature can you recommend on galvanic corrosion in composite metal hybrid structures?
Thanks!
Thanks!
