FATAL ERROR: Unhandled Access Violation Reading 0x42154805 Exception 3
mustangmike
21
I am using Autocad LT 2004. I got the error listed below when trying to open a file. Has anyone seen this or have any ideas?
FATAL ERROR: Unhandled Access Violation Reading 0x42154805 Exception at 42154805h
Mike
service pack installed?
Every *.dwg? Did You try "_recover"?
Lothar
ADT 2004
ACAD 2002
thanks for the reply.
I have installed the service pack. It is only one particular file that I have the problem with. I don't know what you mean "_recover".
Mike
The file I am having a problem with was saved as a dwg file through adobe illustrator.
That may be your issue.
To recover, It should be FILE >> UTILITIES >> RECOVER and then browse to the drawing.
"Everybody is ignorant, only on different subjects." — Will Rogers
Thanks everyone for all your help. Your tips & information has helped me out.
Mike
