Fatigue Doubt 1
Sivadas5791
Automotive
Jul 8, 2020
9
I plan to run analyze a locomotive body structure for + (or) - 20 % vertical loading and use eurocode for aluminium structures for damage calculation .
I plan to run the model for +1.2g and 0.8 g in abaqus.
To calculate the stress range
I plan consider the max principal stress for 1.2g and max. principal stress for 0.8 g.
Stress range = Max Stress at 1.2g - Max Stress at 0.8g
Is my approach of calculating stress range fine ?
In the same element ID where is checked the max.principal, the compressive stresses (min.principal) is zero or negligible?
Hence i ignored the compressive stresses ? is it fine ?
However if i check min. principal in the first place, the maximum compressive stress is on a different location ? So, should i consider the compressive stresses fro stress range calculation ? will it contribute to the fatigue failure ?
You're running linear FEM, yes?
so you don't need to rerun cases for factored loads. You can run a 1g loadase, then factor by 1.2 and 0.8 (post-process).
the max principal stress for 1.2g will be 1.2* the max principal stress from 1g run
the max principal stress for 0.8g will be 0.8* the max principal stress from 1g run … and will be the same element
so the stress range will be 1.2g - 0.8g = 0.4g* the max principal stress from 1g run.
and the stress ratio, R = min/max, will be 0.8/1.2 = 0.6667
I think neglecting the compression component is reasonable, but you do need to check/verify that compressions are low
max principal or von mises are both good stresses for fatigue.
