paramathma
Aerospace
Fatigue life
I need to find the life of a bolt (no of cycles)
I have a bolt, which is subjected to fluctuating Tensile load of 0 to 2000 pounds.
The minimum cross section of the bolt i.e. at the root diameter is .095”.
I then calculated the max stress =max stress/Area, and found the max stress.
The stress ratio is 0.
Can we find the bolt life using the SN curve and the max stress?
I have a simple question
Normally our stress group only provides us the max stress.
They apply the load directly and finds the max stress.
In this the fluctuating load does not comes in to picture.
Then how can we use the stress obtained from the FEA to find the life (component) using the S-N curve?
Please advice
Please advice
