I have a basic question.
My understanding is that one of the ways that simple shear connections accommodate rotations is through localize yielding, for example at bolt holes.
My understanding is also that cyclic loading that is sufficient in magnitude to cause yielding will cause crack growth and fatigue failure.
So can a beam that is subject to high cycle bending loading loads be designed as simply supported, and if so what specific end connections (e.g. double clip angles) are appropriate?
Thanks for your answers.
