baaman
- Jan 24, 2012
- 19
We had a bad regulator on a primary line. Voltage is 7.2, the fault indicators did not work. The indicators are Linam 100 amp trip, made by Chance. The lineman put the indicators on both sides of the regulator, showed white. Disconnected regulator, tried the OCR, and it closed right in and held. Thank you, Bob
