Fe Ni 48 (supra - 50): magnetic annealing
davidmoul
Materials
Jun 20, 2008
60
Hi guys,
just a simple question: during the magnetic annealing of Fe-Ni 48, Do I have to expect some dimensionnal variation on thin laminations (heat treatment at 1100°C under controlled atmosphere).
I'd like to know if I need to adapted the tooling to prevent a deformation of the lamination (I need extreme precision). Is the secondary cristallisation of such alloy a problem from a dimensionnal point of view? I don't find any clues on this point...
I assume that these are laminations that are 4 or 6 mils thick. Given the standard thickness tolerance and stack up variations you will be fine. If you are using a stack of these you will have stack-up tolerance to deal with related to flatness and burr. The dimensions will not be exact.
Plymouth Tube
Many thanks for your help,
In fact, we use these laminations in stack, and we have a very tight tolerances on the inner diameter (35 mm diameter). What kind of dimensionnal variation should I expect on such diameter, for a Magnetic annealing (1100°C) and oxydation.
I will check the tolerances with our mechanical design, but to validate the treatment, I'd like to know what range of dimensionnal change I should expect.
Many thanks for your help!
