Furious.George
Computer
I'm looking into making a thermal battery. I'd like to be able to heat a large block of mass, probably concrete based, to 500 C above ambient. Unfortunately, I don't know much about materials science. I'd like to know more, so to that end I've been reading peer reviewed research on the performance of various mediums for thermal storage. (Citations upon request
Water, paraffin, glycols, and concrete are commonly used, but they all have their shortcomings. For instance, concrete holds a lot of heat, but is a poor conductor of heat. Paraffin holds less heat, but is more efficient at lower temperatures due to the phase change. It also conducts heat poorly. One way to make concrete more thermally conductive is to add paraffin, in order to take advantage of the phase change. One way to make paraffin more conductive is to add aluminum (in the form of aluminum wool). Both of these scenarios have been tested and seem fairly easy to replicate. so I thought I'd give it a shot.
Then it occurred to me: why wouldn't lead work in lieu of paraffin and/or aluminum, for higher temperatures? I know it has a larger coefficient of expansion than most materials, but I thought it might be possible to slowly heat the block while it is drying. Hot enough and the lead would melt, presumably boring out a larger cavity for itself to accommodate future expansion, and without cracking the concrete and injecting air into the system.
Does that sound right?
