Feature Def Error
kr7530
Automotive
Aug 9, 2011
130
I am doing some surfacing and I am getting an error that I do not understand. It seems to only effect "Variable Fillet. Any help with this would be greatly appreciated.
Error:
"Feature Definition Error"
"In-Out Cycle detected in feature structure"​
Thanks,
Kevin
V5R22
Fernando,
I have attached a file, I get the error when I try to run a variable fillet. If I separate the surfaces I can use Shape Fillet without issue. After reconstructing a shelf I no longer had issues (Join.130)
Any help in understanding the error would be much appreciated.
Thanks,
Kevin
 http://files.engineering.com/getfile.aspx?folder=49f1ef2f-76b2-44b9-b480-28cdd2574855&file=In-Out_Cycle.CATPart
I can't see where is your problem, I was able to create a variable fillet on Join 130 (or maybe I did not understand you where to create the variable fillet). Its true that is r25 for me....maybe meanwhile DS fixed some errors in the code...
I would try to run a CATDUAV5 and check the list of the return code detected by CATDUAV5 , maybe you will find something there.
Fernando
- Romania
- EU
Sorry, i should have been more specific. I can't fillet Join.190.
I will try the CATDUAV5
