Related to thread378-239797, I'm interested in design criteria for designing a feed pipe that directs a top-fed fluid onto the inside wall of a tank. If the velocity in the feed pipe is at most 1 m/s to limit static charge generation, how do I ensure that the fluid then flows gently down the wall of the tank without splashing or spraying? I'm going to help things along by angling the feed pipe downward at a 45-degree angle to the tank wall and cut the end of the pipe parallel to the tank wall, but how much gap should I leave? I want to keep it close to minimize the free span that the liquid has to travel, but don't want to restrict it so much that it sprays out - I feel like there's a Froude number and/or momentum calculation at play here.
I understand that part of this solution could involve reducing the velocity out of the feed pipe even further, but as the flow out of this feed pipe decreases, when is the end of the pipe no longer uniformly liquid-full? At some point gravity will take over, and I'll be unable to control the velocity at which it 'pours' out the end of the pipe (i.e. I need to check that I'm designing to a realistic flow regime at the end of the pipe).
A dip tube is not desirable because of the mixing that needs to occur in the tank (high-precision recipe that can't have ingredients remaining within the dip tube that don't get mixed in). Also, we're dealing with combustible fluids (not flammable), which, as I understand it, are only a concern with regard to static charge if they become free droplets - hence the desire for a gentle feed down the wall of the tank.
On a related note, regarding the limit of 1 m/s fluid velocity entering a vessel through an open (not-submerged) feed pipe - is it acceptable to have a higher velocity in a smaller line leading up to the tank, and then increase the pipe/nozzle diameter right as it enters the tank to slow the fluid down? From what I've seen, the velocity limit is as it enters the tank, so, it's ostensibly acceptable, but it's also my understanding that a non-conductive fluid generates charge as it flows through a piping system; so, if it's approaching the tank at high velocity, has it not already accumulated the charge? Does the low-velocity segment of piping need to be long enough to provide for relaxation time?
Similarly, can you use a control valve to throttle the flow down to below the 1 m/s limit at the exit, or does the increased velocity through the valve serve to generate charge counter to your efforts to control it?
