Hol
- Dec 18, 2013
- 20
A motor under no load uses 10 Amps, however at max load draws 120 Amps at 12 Volts.
Usually, I would apply more voltage to the motor(without load) to increase the current. If the total input power is 1440W, and the power source is 1500W, why can't I use a step down transformer to force the voltage to become 12V(or near it) and have that maximum current without any load?
