FEMAP: Create CFAST at multiple points
Salvenheit01
Aerospace
Oct 9, 2024
1
Hi All,
In FEMAP, I need a way to write CFAST, PROP elements at a set of points, prop to prop. It's for hundreds of fasteners, so one by one is really time consuming. Blas Molero referenced similar APIs that worked but only for Weld elements, as I understand it. Does anyone know how to do that in FEMAP or would a new API need to be writte?
Here is the link to the thread from Blas for reference:
(If you Blas see this, thank you so much for all your help with FEMAP on so many threads!)
Thank you,
Salva.
