SolidworksFan
- Feb 7, 2012
- 25
How do you assign different material properties in an assembly? Example, part 1 is 6061-T6 and part 2 is Alloy Steel.
I tried using mesh/geometry/solid, pick the geometry and then Load the material and select the material. Nice and easy. I used the same approach to assign a different material to part 2 but I do not get the Load material choice.
Also, once materials are assigned, how do you check the parts to insure the correct material has been assigned?
