gnault
- Jan 18, 2010
- 8
I have an 8' tall security fence that is attached to a 4' deep x 1.5' wide continuous concrete pedestal/footing. There is a 2' separation grade between the two sides of the pedestal and the pedestal is embedded 2' on the shallow side. I am trying to determine if the 2' embedment is adequate for wind loading.
I know that there are formulas in IBC for embedment depths of circular posts, but my application is for a continuous footing. Thus, I'm not sure that I can use those formulas.
I also tried looking at the pedestal as a sort of "gravity retaining wall" with a wind load, but the embedment depth required comes out to 4+ feet. This doesn't make much sense compared to a Standard Plan of a Noise Wall that I have which only requires 3'-3" embedment for a similar wall height...and the noise wall is a solid wall whereas my fence is not.
Have any of you had any experience doing something like this? If so, what Code or approach did you use to check for embedment?
Thanks for the help!
