feRenumberOpt
aleximos
29
Hey folks,
I'm using the API command feRenumberOpt for renumbering a set of entities. But if I try to edit these entities later in my algorithm, they have the older IDs. Is there a way to edit them according to the new renumbered IDs.
Thanks in advance
Alexandros
I'm on v11.1.1 and don't have the problem you describe. For example create a new model with only one element and run the code below. For me FEMAP returns 1 then 10000, therefore the ID has been updated.
Sub Main
Dim App As femap.model
Set App = feFemap()
Dim el As femap.Elem
Set el =App.feElem
el.First
App.feAppMessage(FCM_NORMAL,CStr(el.ID))
App.feRenumberOpt(FT_ELEM,-el.ID,10000,0,0,False,False,False)
el.First
End Sub
Are you using sets? If yes the IDs in the sets will not be updated. A set is a list of numbers, a set has no idea what it contains and it can therefore not update anything. That would be a group.
AP
Thanks for the answer!
Yes I'm using a set. So I guess it would be better if I make a temporary group.
There are workarounds, depending on how you prefer your code to work.
Perhaps the trackdata object works when renumbering, I've never tested that scenario.
But the underlying concept is the same: you could use a first set with all elements for ex, then renumber, then make a second set with all elements again, then set2-set1 = the elements which have been renumbered.
