Packermanfan
- Jan 4, 2024
- 7
Hi all, I'm trying to convince the people in my office that FFSO flanges can be used in accordance with Section VIII Division 1. Apparently they have only offered RFSO flanges on Code units, even when the customer needs our units to connect to their flat plate flanges on components that are already installed. Even our subcontractor who double-checks calculations has only used raised face flanges on Code units.
Table 2-5.2 has Sketch 1a show gaskets for both flat and raised face flanges. I don't think they need to be designed as Appendix Y flanges as they wouldn't have metal to metal contact anywhere on the flange faces. But then it raises the question, should ring gaskets still be used on flat face connections, or would they be full face in that case?
Before I start suggesting things I want to have enough evidence to convince others that our "standard" designs do not have to be our only designs.
