RCEJD writes, “We constantly run into issues of certain minerals in rocks throwing off our nuke gages.”
Elements in the material being tested may cause false high or low moisture content readings but these same elements do not affect the wet density readings. If the moisture content reading is high or low then, of course, the dry density and percent compaction readings will be low or high; however, a moisture correction factor can be used to make the moisture reading correct and thus the dry density, and percent compaction readings accurate. I have yet to meet the fill material that I couldn’t get an accurate test out of.
Correlation tests? That depends on the following:
Is the material being placed in lifts of required thickness?
Is the material being placed and compacted with appropriate equipment?
Is the material at or near optimum moisture content?
Do we have an accurate proctor and have we run check points to verify we are using the correct proctor?
Is the fill material free of deleterious material (organics, oversized rocks, etc)?
Are we probing the material with a small diameter steel rod to aid in the detection of upper low consistency material as it is being placed and compacted and are we finding the material to be hard and stiff?
Have we observed the hauling vehicles moving over the fill material and have we observed that no deflection, pumping, of the material is occurring?
If the answer to these questions is YES, then no way am I running any silly correlation tests. Pass or fail, my running a test with a nuke gauge, a sand cone, or a drive cylinder is only going to confirm something I already know.
As far as “contractor arguments”, these can be stopped with a tactful reminder of who controls the pencil that is writing up the test results.
Techmaximus
