marinaman
- Mar 28, 2009
- 195
I've got a project where wide flange columns support wide flange beams.
The girder wide flange members frame to the column web via bolted connections.
The erector calls and says that, in the shop, the flanges of the girders weren't coped back far enough to allow the perpendicular beams to be bolted into place (girder flange is in the way of the bolts for the beams coming into column at the column flanges).
He wants to field torch the girder flanges to give him room to bolt the other beams to the column.
I do not like field torching.....but it may be ok here. I know torching changes the steel properties, leaves an ugly irregular edge, etc....but for the first 4" of a girder flange, this may be ok, as there's no load here.
What do you guys think?
