Josep Maria Perdigo
- Feb 22, 2017
- 23
Dear colleagues
I have designed a forged flat head according to fig. UG-34 sketch (b-2) / UG-34(d)(3). The length of flange is quite large, so that the flange-shell weld is away from the corner (radius r) and from the hub (tapered zone).
See attached figure, with dimensions.
The question I have is: Should head-shell welding be governed by figure UW-13.3 / UW-13(g)? In my opinion no, since the welding is not in the hub, therefore it is not a "But-Welded-Hub".
By raising this topic, my intention is to be able to justify to the A.I. that the Tension Test Specimen indicated in figure UW-13.3 / UW-13(g) is not required.
Thank you very much
Thank you very much
