File Exporting Macro 1
MachineSMMC
Industrial
Good Morning
I am looking for a macro that will export an iges file into the current directory. I would like to create a button to execute this macro so I don't have to go into the file save as pull down all of the time.
Chris
Did you try the api help? FYI, you could have cut and pasted everyting you need from there into a macro.
Option Explicit
Dim swApp, Part As Object
Dim BoolStatus As Boolean
Dim LongStatus As Long
Dim e As Long
Dim w As Long
Dim Msg As String
Dim PartName, Rev As String
Sub main()
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
If ((Part Is Nothing) Or (Not (Part.GetType Eqv swDocPART))) Then
Msg = "A part document must be active to use this command!"
LongStatus = swApp.SendMsgToUser2(Msg, swMbWarning, swMbOk)
End
Else
PartName = Part.GetPathName
PartName = Left(PartName, Len(PartName) - 7) & ".igs"
BoolStatus = Part.SaveAs4(PartName, 0, 0, e, w)
If BoolStatus = False Then
Msg = "Failed to save IGS document!"
Else
Msg = "Saved part as " & PartName
End If
End If
Set Part = Nothing
Set swApp = Nothing
End Sub
Where did you find this in the help file?
Chris
Probably SolidWorks.com -> Support -> API Support or Examples. Both have a bunch of these type of examples.
If you look in the API help, there are a bunch of examples. They are listed alphabetically rather than topically, so sometimes it is hard to find a specific call, but there are a bunch there.
Evan T. Basalik, MCSD
It's all about prioritization...
