Hello,UG gurus!
I'm asking this question first in here and maybe afterwards in UG BBS.
In UGII directory there is ug_edit_part_names which you can use to rename parts and to list references.Since almost everyone suggests using master model approach for performance reasons(separate file for drawing) I'm unable to locate drawing file and rename master file using above mentioned utility.
Any explanations or suggestions?
Hopefully problem is understandable.
Henry
Henry
