SM1994
Bioengineer
- Mar 25, 2020
- 49
Hello
According to the attached picture, I have two surfaces (Master surface and slave surface) where there is a gap between them. The slave surface can be inflated with the pressure "P".
I aim to find an appropriate "P" magnitude to fill the gap and only TOUCH the master surface without applying considerable stress.
My question is:
Is there any way Abaqus can use "P" as a variable and iteratively (or any other technique) change it until the Gap becomes zero or very close to zero?
To clarify, I am looking for a way to give the Gap as input, and Abaqus find corresponding "P" to fill the Gap?
Thank you
My question is:
Thank you
