stangman
- Jul 19, 2003
- 3
An existing pressure relief valve (ASME) is presently used on a dirty water system. Occassionally the valve lifts (or weeps) as expected (from thermal expansion) but leaves residual crud in the valve seating area and discharge piping. A suggestion was made to place an inline filter in front of the relief valve. General engineering practice would be not to install a filter in front of the relief valve for the obvious reasons of changing PRV set point values (various filter dPs) and not knowing when the filter is clogged (no continuous flow i.e. no dP).
Are there any ASME or other regulations that prevent the installation of a filter in front of the PRV? This would be used to definitively eliminate this as a possible option.
